I'm binding a custom entity object to my ultragrid, in which, one of the columns is of Datetime type. I have defined the schema manually, but it doesn't display the time, it only shows the date.
I tried changing the DataType of the schema from System.String to System.Datetime, but it gets resetted back to System.String each time I run my application.
Please assist, thanks!
Standard Numeric Format Strings
Custom Numeric Format Strings
you can adjust the format of the column with :
ultraGrid1.DisplayLayout.Bands[0].Columns[1].Format = "DD/MM/YYYY hh:mm";
Hope this helps
