Hello all,
is there any infragistics control like <windows forms richtextbox>,
so that I could put RTF or any special formatted text into that?
which infragistics control does support on exporting control.text into JPG or BMP
so that I could make a "thumbnail" from any strings?
Many thanks in advance
There is no Infragistics control that supports the RTF format, but there is the UltraFormattedTextEditor that supports a custom XML format. As for creating a thumbnail from a control, there is a DrawToBitmap method on the Control class that was added in the 2.0 version of the .NET framework that you can use.
-Matt
