I am getting several errors from the Visual Studio designer when attempting to open user controls containing UltraGrids. Some of the errors listed are...
The type 'Infragistics.Win.UltraWinGrid.UltraCombo'has no property named 'CharacterCasing'
Object of type 'Infragistics.Win.Apperance' cannot be converted to type 'Infragistics.Win.AppearanceBase'
The type Infragistics.Win>ultraWinGrid.UltraGridOverride' has no property named 'HeaderStyle'
These errors are all contained in the .Designer.cs files for the controls, and prevent me from using the VS designer for these controls.
I have previously seen these errors and was able to get rid of them by re-building the project and/or closing and re-opening the solution in VS. Unfortunately these errors are now persistent.
Does anyone know how to fix this?
I am using NetAdvantage 2009 v9.1
Thanks !
But still I am facing issue.I have done following things
But still it gives me error.Only improvement is that now when I compile the project and open the designer view then it's giving the error.
Please remove the older Infragistics references from your .licx file content, and when the new references are needed the content of this file will be populated accordingly to the new version that you are using.
Same issue I am facing....recently we upgraded to 10.3 version.But still my licx file is pointing to older version (7.2).How to update licx file to current version?
Where can we find HotFix. please send me the link
