200
Column Group By row selection
When a column is dragged to the GroupBy area, is the top group by row created after the drop always 'Selected'? If so, do I have to write code to not select it in certain cases.
RM
  • 469350
    Suggested Answer
    Yes.
    If you want nothing to be selected, then yes, you would have to write code to do that.
    To be perfectly frank, I'm not sure why the grid does this. There should probably be a property to turn this off. You should Submit a feature request to Infragistics
