In Ultracombo i have added one column --All---.
When I Short the column ascending, Descending 'All' Value going Down.
It should not Go down. Always on Top.
Is it possible.
Thank you
Hi Mike,
Thanks for your quick reply.
Its working fine
Try this:
private void ultraCombo1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e) { e.Layout.Override.HeaderClickAction = Infragistics.Win.UltraWinGrid.HeaderClickAction.SortMulti; e.Layout.Override.FixedRowStyle = Infragistics.Win.UltraWinGrid.FixedRowStyle.Top; // Assuming that the "--All--" row is the first one. e.Layout.Rows[0].Fixed = true; }
