Hi
I have an UltraGrid with several groups, each group containing one or more columns. I just want the Group headers visible and so set 'ColHeadersVisible = false' on the band to the hide column headers. This worked fine until I upgraded to 2009 vol 1 after which I now see an empty row after group headers.
I noted this type of problem had already been reported and so downloaded and applied hot fix 20091.2013 but the issue has not been resolved for me. Don't know whether the behaviour is slightly different when Groups are used.
Actually, I am a bit confused about the hot fix - the download zip is titled 2013 and dated 28 April but the patch inside it is 2012 dated 23 April.
Adrian
Thanks Mike.
I want group headers visible and column headers hidden so have taken your advice and contacted developer support asking to be notified when a fix becomes available for this known issue.
Hi Adrian,
You are probably referring to this post: Hidding Colum Header in UltraGrid and UltraComboEditor (Version 9.1.) - Infragistics Community.
That post deals with having both the column headers hidden without groups. There's a separate issue when you have group headers visible but column headers hidden. The issue has already been reported to Infragistics and will be fixed in the next hot fix.
If you want to be notified when the fix becomes available, Submit an incident to Infragistics Developer Support and mention development issue #17371.
