1834
Sizing ListView Dropped Down from UltraComboEditor
I feel like there's an obvious answer to this question, but I can't seem to find it.
In order to create a checked dropdown list in my UltraGrid, I have an UltraListView set to checkbox style which is loaded as the dropdown control of an UltraDropDownButton, which belongs to an UltraComboEditor that I am using for the cells in a grid column.  (So I really don't know where to post this, either...)
I know there's supposed to be a built-in way to do this from the 9.1 upgrade, which I have, but I don't see what it is.  Pointing that out to me would be nice.
The problem I am having is that I can't see how to size the UltraListView to fit all its items.  I can't have the user scrolling down to check/uncheck items, they need to be able to click the dropdown button and see all of the list view.  What am I doing wrong?  Is there a way to size the listview to be big enough to fit all the items?  I don't see an ItemHeight or anything like that.  Do I have to do it manually?
  • 71886
    Hello jammerms,
    What you could do as a possible approach to achieve your goal might be by calculating the height of the ultraListView control manually. In my code sample I am taking into account the height of the rectangle of the UIElement of the items and the number of items (+1 if you would like to not have scrollbar at all which shows because of the white space at the end of the items' list).
    Please take a look at the code I mentioned above:
    ultraListView1.Height = ultraListView1.Items[0].UIElement.Rect.Height * (ultraListView1.Items.Count + 1);
    Please do not hesitate to contact us if you need any additional assistance.
