I looked in my "Add/Remove Programs" for an Infragistics Hotfix. I do not see one.I see the Infragistics 2008 vol.1 CLR 2.0 (141 MB), the Infragistics AppStylist 2008 vol.1 CLR 2.0, the 2008 SDK and the 2008 Help.How do you suggest that I uninstall the hotfix for 2123?
Vince,
Thanks for the help. Download and install has fixed the hotfix issue. Things are working great!
duane
Excellent! Thank you for your follow-up.
Installs and is working ;-)
Downloading ;-)
The download should now be updated. It's a much larger file than it was before, which is what it should be - our Windows Forms controls take up much more space than our WinAppStylist application.
Please download the service release again. Let us know, either through the forums or any support case you have open, whether or not this works on your end.
