20
How to control opacity of a child form of "tabbedmdimanager" runtime?
hi.....
i'm using "NetAdvantage for .NET 2008 Vol. 3 CLR 2.0" & "Visual Studio 2005".
i have a mdi parent form with a "ultratabbedmdimanager". i just want to change the opacity of the child forms in runtime. is it possible?
i ve already tried that :
private void toolStripButton10_Click(object sender, EventArgs e)
           this.Opacity = Convert.ToDouble(textBox1.Text);
AND
private void ultraTabbedMdiManager1_InitializeTab(object sender, MdiTabEventArgs e)
            e.Tab.Form.Opacity = Convert.ToDouble(textBox1.Text);
but no one is working. pls help me.
>>> what i want actually is to make the child form area transparent / faded in a tabbedmdimanager. <<<
Parents
No Data
Reply
  • 4032
    I have the same problem (Version 2009.2). Even setting the opacity at designtime of my form, if showed under the tabbed mdi manager as mdi window, opacity is not showed.
    Is there a solution for this post / problem elsewhere?
    I want to set opacity of the mdi form to a lower value than 1.0 while showing a modal form over the mdi form.
    MdiManager.ActiveTab.Form.Opacity = 0.75 but this does not work.
    Thanks for any help.
    Regards
    Markus
Children
No Data
