I have a grid that uses RowLayout so the actually rows are large blocks instead of normal rows. Is it possible to set up the scrolling (vertical) so it smoothly navigates down rows instead of jumping to the beginning of each row? This would mean as you scroll down you would still see part of the above row while seeing part of the beneath row.
Thanks for any information.
Aaron
Mike Saltzman comments on this topic in the following post:http://forums.infragistics.com/forums/p/2113/14570.aspx#14570
This functionality hasn't changed since this post was made. The grid's scrolling functionality is row-based.
