570
How to change the header in girds ColumnChooserControl ?
Hi all !
I'm using the UltraGrids built-in ui ColumnChooserControl.
Now, how can I change the controls header "Field Chooser" ?
My UltraGrid code looks like this:
        private void DefaultInitializeLayout(InitializeLayoutEventArgs e){
            e.Layout.Override.RowSelectors = DefaultableBoolean.True;
            e.Layout.Override.RowSelectorHeaderStyle = RowSelectorHeaderStyle.ColumnChooserButton;
        private void DefaultBeforeColumnChooserDisplayed(BeforeColumnChooserDisplayedEventArgs e) {
            e.Dialog.Size = new Size(250, 250);
            e.Dialog.DisposeOnClose = DefaultableBoolean.False;
            e.Dialog.ColumnChooserControl.MultipleBandSupport = MultipleBandSupport.SingleBandOnly;
            e.Dialog.ColumnChooserControl.Style = ColumnChooserStyle.AllColumnsWithCheckBoxes;
            e.Dialog.ColumnChooserControl.SyncLookWithSourceGrid = false;
            e.Dialog.ColumnChooserControl.DisplayLayout.GroupByBox.Prompt = "Zeilen ein-/ausschalten";
 Trying to change the controls header via
       e.Dialog.ColumnChooserControl.DisplayLayout.GroupByBox.Prompt= "Some string";
 doesn't work.
Any hint or idea is very welcome !
Thanks in advance,
Claus
  • 469350
    Verified Answer
    Hi Claus,
        The text you are referring to has nothing to do with the GroupByBox, it's the text of the dialog.
            private void ultraGrid1_BeforeColumnChooserDisplayed(object sender, BeforeColumnChooserDisplayedEventArgs e)
                e.Dialog.Text = "Some string";
        But if you are trying to localize the strings in your application, you are better off using the ResourceCustomizer. For example, you could do this in Form_Load and it will affect all of the grids in your application.
        Infragistics.Win.UltraWinGrid.Resources.Customizer.SetCustomizedString("ColumnChooserDialogCaption", "Some String");
