I am using the UltraGridPrintDocument to print my grid but as soon as I set the UltraGridPrintDocument.FitWidthToPages = 1. It makes the grid very tiny at top left hand corner, is not doing what it is supposed to do. I just upgraded to 9.1 and created a layout for the grid with 9.1. Any layouts I created with previous versions are fine. Any help please??
No, that's not what I get. My grid goes all the way to the right edge of the page - it fills the page width. And it requires a second page vertically, also.
So this must either be a bug in the version you are using or it's some strange issue with the printer driver.
I have attached a screen shot of the grid and as you can see the columns do not reach the end of the page. Is this what you see??
Your sample works fine for me. The Print Preview comes up and I see the entire grid fit to one page of width.
It's possible that this is a known bug that has already been fixed. I recommend that you get the latest Hot Fix when it comes out. I think it's due to be released this month.
Here is the sample project. I have attached the sample in this post. Thanks in advance.
You can either post the sample here (use the Options tab to attach files to your post), or Submit an incident to Infragistics Developer Support
