355
UltraCombo Issue while try to cancel value change Event
          I want to cancel the value changed Event based on certain condition.
  • based on certain condition i popup one message box with Yes or No Option.
  • If user selects No. I need to cancel the event.
  • I have stored previous value in some variable.
  • I reset the previous value into combo.
  • Messagebox comes twice. That means, the event fires two times.
         If i choose value from the dropdown, then it is ok. But if i type value in the dropdown, then that message comes twice.
What can i do for this? Is any otherway to handle this scenario?
UltraCombo Property:
  • AutoCompleteMode - Append
  • DropDownStyle - DropDown
Event Fired:
  • ItemNotInList - (For Inserting new value into the database)
  • ValueChanged - (For canceling event based on certain condition)
Sample Code
private void ifgCboTest_ValueChanged(object sender, EventArgs e)
try
Cursor =
Cursors.WaitCursor;
if (_isFromValueChanged)
 return;
if (ifgCboTest.SelectedRow != null )
UltraGridRow ugRow = ifgCboTest.SelectedRow;
if (ugRow.Cells["Desc"] != null && ugRow.Cells["Desc"].Value != DBNull.Value && !string.IsNullOrEmpty(ugRow.Cells["Desc"].Text.Trim())) if (!string.IsNullOrEmpty(ifgtxtNotes.Text.Trim()))
DialogResult dlg_Result = MessageBox.ShowMessageBoxYesNo(Resources.Messages.TestDetail, "Continue.It will overwrite existing description", global::Utils.MessageBoxExLib.MessageBoxExIcon.Question);
if (dlg_Result == DialogResult.No) true;
_isFromValueChanged =
//ifgCboTest.SelectedRow = null;
if (_oldID > 0)
Utils.SetValueForCombo(_oldID, ifgCboTest);
else
false;
return;
//TODO }catch (Exception exifgCboTest_ValueChanged)
finally
if (!_isFromValueChanged)
if (ifgCboTest.SelectedRow != null) Convert.ToInt32(ifgCboTest.Value);
_oldID =
else
_oldID = 0;
Cursor =
Cursors .Default;
