When I try to open Date calendar from an ultradatetimeeditor, is launched an exception. I have added an image file with the exception (it is in spanish, sorry). In the previous version didn´t occur this behavior.
What can I do?
Thanks,Carmen
I got around this problem by setting the format provider to en-US and then setting the Mask Input to dd/mm/yyyy (for english format)
This is a known issue which was not discovered until after the volume release. The fix will be available in the first hotfix; you should log an incident so that you receive a notification when it is released.
