I have used Infragistics.Documents.Report.TOC.ITOC to add Table of Contents(TOC) in my custom document report for Navigation to any page while the document has more number of pages.
yeah its working fine and while navigation to the destined page that we look for,after that i need to go back to the Home Page where we navigated from.
This is the problem,How can i navigate back to the page where we from.(i.e)Go Back to the Home Page of TOC Content,for this I need a Home link in every page header of section pages.When i click,that ll navigate back to TOC Home page.
Any Immediate Solution will have Special Appreciations!!!!!!!!!
You could do this through the Hyperlink class, which you apply to an IText element in the header. The first thing that you would need to do is add a target for the link in the table of contents area. For example, if you have the text "Table of Contents" for your TOC area, you would have:
Infragistics.Documents.Report.Text.IText text = section.AddText();text.AddContent("Table of Contents");text.AddTarget("TOC");
Now you need to add a hyperlink that will actually bring the user back to this area:
Infragistics.Documents.Report.Section.ISectionHeader header = section.AddHeader();header.Height = 50;header.Repeat = true;text = header.AddText(10, 20);Infragistics.Documents.Report.Text.Hyperlink link = new Infragistics.Documents.Report.Text.Hyperlink("#TOC");text.AddContent("Table of Contents", link);
-Matt
