Hi folks,
I need to update node appearance based on its value. For example, if node's cell value for Column2 and Column3 are "True", I need to update node's font style to Bold. My question is, what is the best way to do this?
Many thanks.
thanks very much Brian.
Handle the CellValueChanged event, and use the e.Column property to determine which column's cell value has changed; then use the e.Node property to get a reference to the node, then set the UltraTreeNode.Override.NodeAppearance.FontData.Bold property to true.
