Hello;
This post may be in the wrong area, but I've seen that Mike is answering LinkLabel questions., so here goes. I've got an UltraFormattedLinkLabel in a grid cell and everything works great, for web urls as well as text files or .pdf's on a hard drive. But what if a link points to say, a non exeistent text file? The control seems to just ignore the click on the link. I couldn't find an event to handle this, "File doesn't exist", situation; am I missing it or is there a better solution thatn using the UltraFormattedLinkLabel?
Maybe in a way that I call diagnosics.Process instaed of letting the UltraFormattedLinkLabel control do all the work, like grabbing the LinkClicked event and calling Process.Start()?
I just found this: (at http://forums.infragistics.com/forums/p/16950/61585.aspx)
"The LinkClicked event has an OpenLink property that defaults to True; this property determines whether the .NET Process class should be used to start a process by that name. Since you are handling this action yourself, you should set the property to False."
So I guess I'll use the OpenLink property and do the Process.start myself in a try catch. Make sense? BTW, I only found the OpenLink property with intellisense - it wasn't in the docs.
Bill
My mistake about the docs - I realized that .OpenLink property was on the LinkClickedEventArgs object, not the linkLabel. Duh.
Thanks, Mike.
Hi Bill,
netctlb73 said:So I guess I'll use the OpenLink property and do the Process.start myself in a try catch.
Yes, I think that's the way to go.
