440
Change Drop Down Value - Error
I have a DropDown that I set as the ValueList to a column in a WinGrid(2008 vol 3).  The dropdown values are built from LINK to SQl call.  I return a List<Table>.  However, everytime I try to change the value I get this error.
Unable to update the data value: Operation is not valid due to the current state of the object.
Here is the code I use.
        private void ugSystem_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e)
            Infragistics.Win.UltraWinGrid.UltraDropDown udd;
            udd = new Infragistics.Win.UltraWinGrid.UltraDropDown();
            udd.DataSource = b.PIFactory.GetFactSystemAttributeName().GetDropDown();
            udd.ValueMember = "attributeNameID";
            udd.DisplayMember = "description";
            e.Layout.Bands["SystemAttributes"].Columns["attributeNameID"].ValueList = udd;
