The UltraFormattedTextEditor has the property ScrollBarDisplayStyle. This property can be set with an enumerator, and the options in the enumerator are: Automatic, Always and Never. Is there a way for me to set the Vertical scrollbar to be Automatic and the horizontal scrollbar to Never show?
Thank you very much! It works great.
-Glenn
There's nothing exposed publically that would allow you to do this, but if your application will have reflection permissions, you could hack this with a CreationFilter:
public class CF : IUIElementCreationFilter{ public void AfterCreateChildElements(UIElement parent) { if (parent is FormattedLinkEmbeddableUIElement) { ScrollableAreaUIElement scrollElement = parent.GetDescendant(typeof(ScrollableAreaUIElement)) as ScrollableAreaUIElement; if (scrollElement != null) { PropertyInfo info = typeof(ScrollableAreaUIElement).GetProperty("HorizScrollbarVisible", BindingFlags.NonPublic | BindingFlags.Instance); if (info != null) info.SetValue(scrollElement, false, null); } } } public bool BeforeCreateChildElements(UIElement parent) { return false; }}
this.ultraFormattedTextEditor1.CreationFilter = new CF();
-Matt
