453
Adding a new record to ultragrid
I am using UltraGrid in my application. It is bound to a BindingSource, which in turn is bound to a BindingListView. Bindinglistview contains the details about my business objects, the structure is defined in the class. e.g.  Books - Name, Author, Description
Now, when I try to populate the grid, it works fine. But I need to know how should I add the data such that, it is reflected in the business objects also.
Can anyone please advise me on this?
  • 469350
    Suggested Answer
    What part of this is giving you trouble?
    If you wan the user to be able to add new rows to the grid, you would set the AllowAddNew property on the Override. TemplateOnBottom is a popular option which gives the user an addnew row at the bottom of each island of data.
    If you want to add a row in code, then it's probably easier to just add the row to the data source rather than through the grid.
