I am working on UltraWinGrid.
i am getting the OutOfMemoryException when i bind more than 1 lakh records.. I have tested with the following records and the appropriate
results are mentioned below.68,999 records - Able to display in the grid.90,000 records - It Fails.See the exception details below..
How to bind a table which has more than 1 lakh records?
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.************** Exception Text **************System.OutOfMemoryException: Exception of type 'System.OutOfMemoryException' was thrown. at Infragistics.Win.UltraWinGrid.RowsCollection.AllocateNewRow() at Infragistics.Win.UltraWinGrid.RowsCollection.SyncRowsHelper(IList boundList) at Infragistics.Win.UltraWinGrid.RowsCollection.SyncRows() at Infragistics.Win.UltraWinGrid.RowsCollection.EnsureNotDirty() at Infragistics.Win.UltraWinGrid.ScrollCountManagerSparseArray.VerifyAgainstScrollVersion() at Infragistics.Win.UltraWinGrid.ScrollCountManagerSparseArray.GetItemAtVisibleIndex(Int32 visibleIndex) at Infragistics.Win.UltraWinGrid.RowsCollection.GetRowAtVisibleIndex(Int32 visibleIndex, Boolean includeSpecialRows) at Infragistics.Win.UltraWinGrid.RowsCollection.GetFirstVisibleRow(Boolean includeSpecialRows) at Infragistics.Win.UltraWinGrid.RowsCollection.GetFirstVisibleRow() at Infragistics.Win.UltraWinGrid.RowScrollRegion.get_FirstRow() at Infragistics.Win.UltraWinGrid.RowScrollRegion.GetMaxScrollPosition(Boolean scrollToFill) at Infragistics.Win.UltraWinGrid.RowScrollRegion.EnsureScrollRegionFilled(Boolean calledFromRegenerateVisibleRows) at Infragistics.Win.UltraWinGrid.RowScrollRegion.RegenerateVisibleRows(Boolean resetScrollInfo) at Infragistics.Win.UltraWinGrid.RowScrollRegion.RegenerateVisibleRows() at Infragistics.Win.UltraWinGrid.RowScrollRegion.WillScrollbarBeShown(ScrollbarVisibility assumeColScrollbarsVisible) at Infragistics.Win.UltraWinGrid.ScrollRegionBase.WillScrollbarBeShown() at Infragistics.Win.UltraWinGrid.ViewStyleBase.AddBandHeaders(ColScrollRegion csr, UltraGridBand band) at Infragistics.Win.UltraWinGrid.ViewStyleVertical.RecreateHeaderList(ColScrollRegion csr) at Infragistics.Win.UltraWinGrid.ColScrollRegion.RegenerateVisibleHeaders() at Infragistics.Win.UltraWinGrid.ColScrollRegionsCollection.InitializeMetricsHelper() at Infragistics.Win.UltraWinGrid.ColScrollRegionsCollection.InitializeMetrics() at Infragistics.Win.UltraWinGrid.DataAreaUIElement.PositionChildElements() at Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive) at Infragistics.Win.UltraWinGrid.DataAreaUIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive) at Infragistics.Win.UltraWinGrid.DataAreaUIElement.set_Rect(Rectangle value) at Infragistics.Win.UltraWinGrid.UltraGridUIElement.PositionChildElements() at Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive) at Infragistics.Win.UltraWinGrid.UltraGridUIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive) at Infragistics.Win.UIElement.VerifyChildElements(Boolean recursive) at Infragistics.Win.UltraWinGrid.UltraGridUIElement.InternalInitializeRect(Boolean verify) at Infragistics.Win.UltraWinGrid.UltraGridLayout.GetUIElement(Boolean verify, Boolean forceInitializeRect) at Infragistics.Win.UltraWinGrid.ColScrollRegion.get_SafeExtent() at Infragistics.Win.UltraWinGrid.ColScrollRegion.get_ClippedExtent() at Infragistics.Win.UltraWinGrid.ColScrollRegion.CheckIfSizeChanged() at Infragistics.Win.UltraWinGrid.ColScrollRegionsCollection.CheckIfSizeChanged() at Infragistics.Win.UltraWinGrid.UltraGridUIElement.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode) at Infragistics.Win.UltraControlBase.OnPaint(PaintEventArgs pe) at Infragistics.Win.UltraWinGrid.UltraGrid.OnPaint(PaintEventArgs pe) at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs) at System.Windows.Forms.Control.WmPaint(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)************** Loaded Assemblies **************mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll----------------------------------------Microsoft.VisualStudio.HostingProcess.Utilities Assembly Version: 8.0.0.0 Win32 Version: 8.0.50727.42 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualStudio.HostingProcess.Utilities/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.HostingProcess.Utilities.dll----------------------------------------System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll----------------------------------------Microsoft.VisualStudio.HostingProcess.Utilities.Sync Assembly Version: 8.0.0.0 Win32 Version: 8.0.50727.42 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualStudio.HostingProcess.Utilities.Sync/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.HostingProcess.Utilities.Sync.dll----------------------------------------System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll----------------------------------------Infragistics2.Win.UltraWinEditors.v8.1 Assembly Version: 8.1.20081.1000 Win32 Version: 8.1.20081.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinEditors.v8.1/8.1.20081.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinEditors.v8.1.dll----------------------------------------System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.configuration/2.0.0.0__b03f5f7f11d50a3a/System.configuration.dll----------------------------------------System.Data Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll----------------------------------------System.Deployment Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Deployment/2.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll----------------------------------------System.Design Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll----------------------------------------System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll----------------------------------------System.Runtime.Serialization.Formatters.Soap Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Serialization.Formatters.Soap/2.0.0.0__b03f5f7f11d50a3a/System.Runtime.Serialization.Formatters.Soap.dll----------------------------------------System.Web Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll----------------------------------------System.Web.Services Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll----------------------------------------System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll----------------------------------------Microsoft.VisualBasic Assembly Version: 8.0.0.0 Win32 Version: 8.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dllAccessibility Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll----------------------------------------System.Runtime.Remoting Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Data.OracleClient Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data.OracleClient/2.0.0.0__b77a5c561934e089/System.Data.OracleClient.dll----------------------------------------System.Management Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
Infragistics2.Win.v8.1 Assembly Version: 8.1.20081.1000 Win32 Version: 8.1.20081.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.v8.1/8.1.20081.1000__7dd5c3163f2cd0cb/Infragistics2.Win.v8.1.dll----------------------------------------Infragistics2.Win.UltraWinStatusBar.v8.1 Assembly Version: 8.1.20081.1000 Win32 Version: 8.1.20081.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinStatusBar.v8.1/8.1.20081.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinStatusBar.v8.1.dll----------------------------------------Infragistics2.Shared.v8.1 Assembly Version: 8.1.20081.1000 Win32 Version: 8.1.20081.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Shared.v8.1/8.1.20081.1000__7dd5c3163f2cd0cb/Infragistics2.Shared.v8.1.dll----------------------------------------Infragistics2.Win.UltraWinGrid.v8.1 Assembly Version: 8.1.20081.1000 Win32 Version: 8.1.20081.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinGrid.v8.1/8.1.20081.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinGrid.v8.1.dll----------------------------------------System.Transactions Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Transactions/2.0.0.0__b77a5c561934e089/System.Transactions.dll----------------------------------------System.EnterpriseServices Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.EnterpriseServices/2.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll----------------------------------------************** JIT Debugging **************To enable just-in-time (JIT) debugging, the .config file for thisapplication or computer (machine.config) must have thejitDebugging value set in the system.windows.forms section.The application must also be compiled with debuggingenabled.For example:<configuration> <system.windows.forms jitDebugging="true" /></configuration>When JIT debugging is enabled, any unhandled exceptionwill be sent to the JIT debugger registered on the computerrather than be handled by this dialog box.
Ashok
I tried this out and it works fine for me. I am able to create a grid with 100,000 rows with no problems. And I know from the forums that there are many others using the grid with far more rows than that.
One thing I noticed is that you are using the release version of the v8.1 grid. Perhaps you need to get the latest hot fix. There may have been a bug in the older version.
