686
Yet another infragistics bug. Another one for UltraDayView
1) Place an UltraDayView control on a form
2) Go to the MouseMove event of the control
3) Add some code to let you see when the event is being fired (i.e. have a label as a counter which increases each time the event fires)
4) Run the application.
Hover the mouse over the control, now DO NOT MOVE THE MOUSE for the next instructions.
Press the mouse button down to select a timeslot. When you release the mouse button, you will see that the event has fired.
Now click the mouse button on the timeslot you selected again. This time the event fires twice.
The mouse cursor has not moved during any of these operations - yet the mousemove event is being fired. What gives? Surely this is not the expected behaviour. It is causing me headaches because im dealing with drag and drop while also trying to keep the double click event working correctly.
