I've got a UltraWinGrid bound to a UltraDataSource. I've used design-time to create the column/band layouts in the UltraDataSource. The UltraWinGrid is design-time bound to the UltraDataSource.
In code in my LoadData() routine, I load the UltraDataSource row by row, band by band (one root band, one child band("Location")) like this:
For Each t As RFATariff In Card.TariffList.Values Dim dr As UltraDataRow = dsPricing.Rows.Add
dr("TariffKey") = t.TariffKey
... etc ...
Dim LocationRows As UltraDataRowsCollection = dr.GetChildRows("Location") For Each l As RFALocation In t.LocationList.Values Dim ldr As UltraDataRow = LocationRows.Add ldr("LocationKey") = l.LocationKey ...etc...
Next Next For Each c As UltraGridColumn In dgrPricing.DisplayLayout.Bands(0).Columns c.PerformAutoResize(PerformAutoSizeType.AllRowsInBand, True) Next For Each c As UltraGridColumn In dgrPricing.DisplayLayout.Bands("Location").Columns c.PerformAutoResize(PerformAutoSizeType.AllRowsInBand, True) Next
All this works fantastic.
My problem comes when I want to reload the form.
I tried dsPricing.Rows.Clear() but this cleans out the layout of the ultradatasource....
I hate it if I'm missing something simple, but how can I just clear out the datarows from the entire data source without resetting properties/settings at the same time?
To what issue are you referring? Are you saying that even when you save the layout and re-load it, it's not working? The grid is still losing it's layout?
I have no explanation for that. I don't see anything obviously wrong with the code you have here, but it's always hard to tell from a code snippet when you can't actually run it.
Perhaps you could try to duplicate the problem in a small sample project and post it here so I can take a look.
Hi Mike,
As mentioned, I used the DisplayLayout.SaveXML method to save the layout the stream and tried to load using the LoadLayout metho. Please guide where i m going wrong
In fthe Form_Load, adding the code for saving the Layout in xml format.
In Form_Load System.IO.FileStream fs = null; string XML_LAYOUT_FILE_PATH = @"C:\\testlayout.xml"; // Open a new file to save the layout to. fs = new System.IO.FileStream(XML_LAYOUT_FILE_PATH, System.IO.FileMode.Create, System.IO.FileAccess.Write, System.IO.FileShare.None); this.benefitPlanIncomeUltraGrid.DisplayLayout.SaveAsXml(fs, PropertyCategories.All); fs.Close();
In the button click event, clearing the gridrows.
private void clearAllButton_Click(object sender, EventArgs e) { System.IO.FileStream fs = null; string XML_LAYOUT_FILE_PATH = @"C:\\testlayout.xml"; MessageBox.Show(benefitPlanIncomeUltraGrid.Rows.Count.ToString()); foreach (UltraGridRow rows in benefitPlanIncomeUltraGrid.Rows) { if (!rows.IsDeleted) { rows.Delete(false); } rows.Refresh(); } benefitPlanIncomeUltraGrid.Rows.Refresh(RefreshRow.ReloadData, true); //MessageBox.Show(benefitPlanIncomeUltraGrid.Rows.Count.ToString()); //benefitPlanIncomeUltraGrid.Rows.Refresh(RefreshRow.ReloadData, true); // this.benefitPlanIncomeUltraGrid.ResetDisplayLayout(); this.benefitPlanIncomeUltraGrid.DisplayLayout.Bands[0].RowLayouts.Clear(); // this.benefitPlanIncomeUltraGrid.DisplayLayout.Rows.Band.ResetRowLayouts(); fs = new System.IO.FileStream(XML_LAYOUT_FILE_PATH, System.IO.FileMode.Open, System.IO.FileAccess.Read, System.IO.FileShare.Read); this.benefitPlanIncomeUltraGrid.DisplayLayout.LoadFromXml(fs, PropertyCategories.All); fs.Close(); }
Please help to resove the issue. It is very urgent.
JIJIL
Mike Saltzman"] Your workaround seems reasonable, but the user will lose any state-specific information. For example, if the user resized a column, it will revert to it's original size when you clear the rows. So what you might want to do is use the grid.DisplayLayout.Save method to save the layout to a stream and then re-load it after you clear the rows.
Nice... sounds just like what I needed to do. I'll give that a go and see how it works out. Thanks for the tip!
Great product and excellent support. Keep up the good work!
I agree that it's strange. That should not be happening. There's no reason why the grid should be losing it's layout when you simply clear the rows collection - unless clearing the root-level rows collection is somehow destroying the child band and causing the UltraDataSource to send a Reset notification.
Sounds like a bug to me.
What I meant was:
When you do the dsPricing.Rows.Clear(), the associated UltraGrid loses all it's layout information.
It's so strange to me that you can create an UltraGrid layout in the design-time designer, attach the UltraDatasource and everything works fine-- but clear out the rows in the UltraDatassource and all your grid layout settings go with it.
I expected the grid component to maintain it's layout settings even if the bound datasource was removed or empty. ;-)
I've since solved the issue by moving the grid layout code into the Initialize_Layout event. Everything working fine now.
