235
Data Binding
Hi
Can I bind single row of a dataset table to more than one properties of a control?
I am currrtly binding three properties of a control to dataset single row. Properties value are showing correctly, but when I am updating properties, then same is not reflecting in dataset. When I tried to debug, i found that only first property value is geeting updated to dataset, but for other two its going into getter first, then setter. Three properties are of same type and three columns in dataset are also of same type...There is nothing different in them
Please help if there is something that I need to do for same
Narinder
  • 69832
    It might help to know which control(s) are players in this, and what data types are being bound. If you can post a sample project that demonstrates the issue and we can take a closer look.
