195
UltraComboEditor Datasource problem
So I am adding a UltraComboEditor to a UltraGrid on the fly as the editor control for a cell. I do this in the after row insert event.
When I set the datasource (an UltraDataSource) of the UltraComboEditor I don't see the items on the UI. It looks as though there is no datasource at all. The datasource is fine as it works if I use the UltraCombo control instead.
What extra step do I need to perform with the UltraComboEditor to get it to show the items from the datasource?
This is the relevent code:
/// <summary>
/// Row Inserted
/// </summary>
/// <param name="sender"></param>
/// <param name="e"></param>
private void RequestGrid_AfterRowInsert(object sender, RowEventArgs e) {
    // account mappings only past this point
    if(e.Row.Band.Index != 1) {
        return;
    // get the account number
    string accountNumber = e.Row.ParentRow.Cells["AccountNumber"].Value.ToString();
    // jig up an account
    Account A = new Account(accountNumber);
    // get instances
    ChartDataCache DataCache = ChartDataCache.Instance;
    // get rowsets
    DataRow[] Rowsets = DataCache.AccountDetailData.Tables["Rowsets"].Select("CompanyNumber = '" + A.CompanyNumber + "'");
    // rowset edit control
    UltraComboEditor RowsetComboEditor = new UltraComboEditor();
    RowsetComboEditor.Name = Guid.NewGuid().ToString();
    RowsetComboEditor.Visible = false;
    // set datasource
    RowsetComboEditor.DisplayMember = "RowsetName";
    RowsetComboEditor.ValueMember = "RowsetName";
    // bind
    BindToRows(RowsetComboEditor, Rowsets, "(Select)", "(Select)", "(None Available)");
    // add it to the grid and set it as the edit control
    RequestGrid.Controls.Add(RowsetComboEditor);
    e.Row.Cells["RowsetName"].EditorControl = RowsetComboEditor;
/// <summary>
/// Bind a menu to a list of data rows
/// </summary>
/// <param name="Menu"></param>
/// <param name="Rows"></param>
private void BindToRows(UltraComboEditor Menu, DataRow[] Rows, string initialText, string initialValue, string emptyVal) {
    try {
        // flag an empty set
        bool emptySet = Rows.Length == 0;
        // anything there?
        if(emptySet) {
            // create data to represent an empty set
            DataTable T = new DataTable("Empty");
            T.Columns.Add(Menu.DisplayMember, typeof(string));
            T.Columns.Add(Menu.ValueMember, typeof(string));
            T.Rows.Add("(None Available)", emptyVal);
            Rows = T.Select();
        // data source instance
        UltraDataSource S = new UltraDataSource();
        // add columns
        foreach(DataColumn C in Rows[0].Table.Columns) {
            S.Rows.Band.Columns.Add(C.ColumnName);
        if(!emptySet) {
            if(Rows.Length > 1) {
                DataRow SelectRow = Rows[0].Table.NewRow();
                SelectRow[Menu.DisplayMember] = initialText;
                SelectRow[Menu.ValueMember] = initialValue;
                S.Rows.Add(SelectRow.ItemArray);
        // add data
        foreach(DataRow R in Rows) {
            S.Rows.Add(R.ItemArray);
        // set data source
        Menu.DataSource = S;
    catch(Exception ex) {
