I have an ultragrid bound to a dataset (IList). I have the SortIndication set on the first column.
When I then load data into the dataset the sortindicatior is ignored until I click the column header. What would be the intended way to have the grid trigger a sort when after new data is loaded?
regards
Stefan
I believe this is a bug that was recently addressed; you might want to report it so that you receive a notification when the fix becomes available.
