I am trying to determine the best control to use in my scenario. I have tried both controls mentioned in the subject, but usually come across some caveat I don't like, unless of course I'm mistaken.
For example I really like the way the ComboBoxEditor behaves. I like the fact GUI looks prettier. By that, I like how when I mouse over an item, it highlights that row with the pretty Office 2007 style. Something I can't seem to do in the ComboBox. However in the ComboBox I can have multiple columns that the user can stretch so that if the text is too big he can still read it. This is something I can't seem to do in the ComboBoxEditor.
Is there some way to have one of the controls perform this:
Thank you in advance!
Close enough, that works! Thank you.
It sounds like the UltraCombo has everything that you want except for the built-in resolution for the Office2007 hot-tracking. You can achieve a look that is very close to the UltraComboEditor's hot-tracking by setting the HotTrackRowAppearance, such as the following:
private void ultraCombo1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e){ e.Layout.Override.HotTrackRowAppearance.BackColor = Infragistics.Win.Office2007ColorTable.Colors.ButtonHighlightGradientDark; e.Layout.Override.HotTrackRowAppearance.BackColor2 = Infragistics.Win.Office2007ColorTable.Colors.ButtonHighlightGradientLight; e.Layout.Override.HotTrackRowAppearance.ForeColor = Infragistics.Win.Office2007ColorTable.Colors.ButtonForeColorHighlight; e.Layout.Override.HotTrackRowAppearance.BackGradientStyle = Infragistics.Win.GradientStyle.GlassTop50Bright; e.Layout.Override.HotTrackRowAppearance.BorderColor = Infragistics.Win.Office2007ColorTable.Colors.ButtonHighlightBorderGradientDark; e.Layout.Override.HotTrackRowAppearance.BorderColor2 = Infragistics.Win.Office2007ColorTable.Colors.ButtonHighlightBorderGradientLight;}
This will not be exactly the same as the UltraComboEditor's hot-tracking because the ValueListItems custom-draw their borders to have a 1px inner border (Office2007 buttons will do the same thing), but otherwise these are the same colors used in the resolution of the UltraComboEditor's items.
-Matt
