3555
Movebale Datapoint...
I am using the class DraggingDataPointTool.cs from the samples explorer to move my datapoints.  However, the datapoints value seems to change, but the chart is not redrawing the new location.
I stepped through the following method in that class and i think the problem has to do with this.UltraChart.InvalidateLayers();   I can't seem to figure it out.  Is there a property on the chart I need to change to allow this?
public override void MouseMove()
            base.MouseMove();
            if (this.draggingPrimitive == null)
                return;
            // get the datapoint off the primitive
            NumericDataPoint dataPoint = this.draggingPrimitive.DataPoint as NumericDataPoint;
            if (dataPoint == null)
                return;
            // change the datapoint value and invalidate the chart.
            dataPoint.Value = (double)this.axisY.MapInverse(this.LastInput.ViewPoint.Y);
