By default the summaries have a caption row and a value row, I don't like the looks of this and would like the caption to be on the values row so that there is only one row, attached is a picture of how it works on the left and I would like it on the right(by some bad photoshop) thank you, Jamie
Did you set the CreationFilter property of the grid?
when I put that code in a form, it never gets called...a working example of that would be much easier to follow
Check out this thread: My Creation and Draw Filters Article - Infragistics Forums
