340
Is it possible to fix one column in a grid?
Hello-
I have a grid with one column that I'd like to fix (freeze in place) so when the user scrolls all of the other columns scroll except that one.
I can achieve this by turning Fixed Headers on (in the designer) and then doing this: ultraGrid1.DisplayLayout.Bands[0].Columns[0].Header.Fixed = true;
However by turning them on, it allows the user to pin/freeze/fix any other column that they want, and I do not want this behavior. Any way to disable the other columns? I'm looking maybe for a Before event that will fire when they click on the little pin icon where I can simply cancel.
Thanks much in advance!
  • 22852
    Suggested Answer
    You can prevent the user from being able to pin columns by not showing the fixed header indicators.  The following code accomplishes this:
    this.ultraGrid1.DisplayLayout.Override.FixedHeaderIndicator = Infragistics.Win.UltraWinGrid.FixedHeaderIndicator.None;
    Alan
