When I set more than one Infragistics control to have identical tooltip text, I frequently get an error caused by a line beginning with:
Infragistics.Win.UltraWinToolTip.UltraToolTipInfo ultraToolTipInfo3 = new Infragistics.Win.UltraWinToolTip.UltraToolTipInfo(resources.GetString("cmBuildings.UltraToolTip"), Infr....
This line has been moved too high in the designer.cs file for the form in question. I end up having to manually relocate the line to a point after all items mentioned in this code line have been properly declared so that the program will compile properly. This problem has existed for more than a year or two, I keep expecting to see it go away in the course of normal maintenance and improvements, but it seems to still be there!
The error seen in the ide says something like resources cannot be used before they are declared.
Bob Graham
hi mike.
we're having the same problem rvgraham789 is having. What hotfix was this fixed in?
we're using v 8.1.20081.2013
thanks
Using 8.2, the original ending 1000... I suppose I could check out 8.3, but I have no other issues at this time and I'm a bit shy about having to update all my users machines. Wimpy excuse, I know... I was hoping there was some workaround by putting a declare somewhere or something so the resources line couldn't precede the dependent declares.
Hi Bob,
What version are you using? We did fix some issues with the serialization of resources recently - like toward the end of last year. You might need to just get the latest hot fix.
If that does not help, you should Submit an incident to Infragistics Developer Support and include a small sample project demonstrating the error so we can get this fixed.
