I have downloaded the sample code to place a checkbox in the column header.
When the program gets to the Sub AfterCreateChildElements and runs the line aColHeader = CType(parent, HeaderUIElement).Header, I get this error message :
Unable to cast object of type 'Infragistics.Win.UltraWinGrid.BandHeader' to type 'Infragistics.Win.UltraWinGrid.ColumnHeader'.
Is there something in my grid that causes this or does it need another test for BandHeader here?
The easiest thing to do is just to check the Header and make sure it's a ColumnHeader before you assign it to aColHeader:
if typeof CType(parent, HeaderUIElement).Header is ColumnHeader Then
Another way to do it would be to check if the column is not null:
if CType(parent, HeaderUIElement).Column != null Then
Mike,
You are correct. The original post does not have a BandHeader. And I am trying to figure out the code to test a HeaderUIElement to see if it is a Band Header or Column Header.
I guess the original sample didn't have any BandHeaders in the grid. You should probably just check to make sure that Header is a ColumnHeader before proceeding.
