865
Row insertion not supported by this data source. (how to add a new row?)
I am new to UltraGrid control. I would like to populate th grid on runtime when user select an item from a combo box, data inserts into the grid .... and when user select another item from combo box, data should append to the grid.
i believe i can not use datasource in this scenario.
i have only one band in the grid. I get this error message: "Row insertion not supported by this data source".  I tried to set AddNew property to true but it set itself to False.
This is the code i have written:
Private Sub cmboCategory_ValueChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles cmboCategory.ValueChanged
Me.cmboCatPart.Items.Clear()
Dim lngCatIdx As Long = MobService.GetServiceCatItemID(cmboCategory.SelectedItem.ToString)
For Each drPartsx As DataRow In MobService.ListSubItems(lngCatIdx, False).Rows
Dim invRow As UltraGridRow = Me.gridInvoice1.DisplayLayout.Bands(0).AddNew
invRow.Cells(0).Value = drPartsx.Item(1).ToString
Me.cmboCatPart.Items.Add(drPartsx.Item(1).ToString)
Next
lngCatIdx = Nothing
End Sub
 Thanks for your help.
Kamal
