Hi!
I wanted to add calculated column to my grid but after I just placed UltraCalcManager control on my form, entire application hangs after InitializeComponent() for this form. I didn't put any code for a new column yet and have no idea where it can hang. Formula sample from sample chooser works great and my small sample application too. Can you suggest something? My application is too big to attach it.
Mila.
Hi Mila,
The first thing I recommend is that you try downloading the latest Hot Fix from the Infragistics web site. Perhaps there is a bug that was already fixed.
If that doesn't help, when exactly does the program hang? You say after InitializeComponent, so this is when yuo run your application? If the program is hanging when you run it, then you should be able to break the execution and take a look at the Call Stack. That might give us a clue about what's locking it up.
Another thing you might try, just as a test, is to set the grid's MaxBandDepth to a low number like 5, just to see if that makes any difference.
