135
How to do create table??
 hi every body!
i am want to create a table with name of column is date time??
thanks help me.
  • 469350
    There are lots of samples of this in the NetAdvatange SDK and on the web site.
    How you create the data in your grid depends on a lot of different factors. If you are getting your data from a database, then you will probably want to use a DataTable or DataSet. In which case, you will need to consult Microsoft documentation on how to create a DataSet from your database.
    If you just want to create some data in code without any back end, then you have a number of options. The simplest of these would be to use the UltraDataSource component. In fact, if you place a new grid on a form, the grid's QuickStart designer will pop up and walk you through this process.
