Can somebody tell me how to set a tooltip on an ultraTreeNode, I've been searching a lot lately but I can't figure it out.
is it that complicated?
I saw this code
private void ultraTree1_MouseEnterElement(object sender, Infragistics.Win.UIElementEventArgs e) { if (e.Element is Infragistics.Win.UltraWinTree.NodeTextUIElement) { Point pt = new Point(e.Element.Rect.X, e.Element.Rect.Y); Infragistics.Win.UltraWinTree.UltraTreeNode node = this.ultraTree1.GetNodeFromPoint(pt); if (node != null) { Infragistics.Win.UltraWinToolTip.UltraToolTipInfo tipInfo = new Infragistics.Win.UltraWinToolTip.UltraToolTipInfo(node.Text, Infragistics.Win.ToolTipImage.Default, "", Infragistics.Win.DefaultableBoolean.True); this.ultraToolTipManager1.SetUltraToolTip(this.ultraTree1, tipInfo); this.ultraToolTipManager1.ShowToolTip(this.ultraTree1); this.ultraToolTipManager1.GetUltraToolTip(this.ultraTree1); } } else this.ultraToolTipManager1.HideToolTip(); }
but it doesn't seem to work, nothing shows up
does sy have an example of a working code?
Thx
The above code work fine except for a little issue where the UltraTree holds onto the last tooltip that is applied to it. So, if you leave the ultratree1 control and move the mouse back over the ultratree1, the last tooltip will popup. The else part of the code should read as follows
else
this.ultraToolTipManager1.SetUltraToolTip(this.ultraTree1, null);
Juscher said:I understand it conflicts with the default tooltip you mentioned
Thank you, Brian. I will see what I can do with the sample code provided here. I just want additional information to be displayed when the mouse pointer hovers over a tree node, but I understand it conflicts with the default tooltip you mentioned.
Juscher said:...there must be another way
Hello !
I am replacing a standard tree by an UltraTree. On the standard tree there was a simple way to handle tooltips, which could be affected directly to the nodes and could be read when needed, like this :
node.ToolTipText
I am looking to a way to do this with the UltraTree. The code above is far too long for what I want to do - there must be another way. Could you tell me which attribute I have to use to read the tooltip of a particular UltraTreeNode ?
