I am not able to print multiple grids (in single print document) with different headers as follows:
I understand that you'd like to print multiple grids, using different headers, utilizing a single WinGridPrintDocument.
As Mike mentions in the thread I linked to, it's only possible to print data from multiple grids on the same WinGridPrintDocument if you aggregate the data into a single, separate grid. Since you need different headers for each "grid," aggregating the data becomes an option you likely can't use.
Using the Documents engine is the best alternative available.
Vince,
Thank you for the help, but I want to show more than 1 grid with different headers in print preview using ultraGridPrintDocument.
Shalabh
This topic is discussed in the following thread:http://forums.infragistics.com/forums/t/16057.aspx
Another option is to instead use the Infragistics Documents engine to export both grids to a single PDF or XPS document.
