I'm using wingird with different groups levels and have implemented IMergedCellEvaluator Interface. But my "ShouldCellsBeMerged" function is not getting called.
If i reomved the groups related code then that time "ShouldCellsBeMerged" function is getting called.
Please let me know what is the problem. I have attached my sample application with code.
Amit Pardeshi
Hi Amit,
I'm not sure what you mean by "If i reomved the groups related code".
Also, I am unable to run your sample. The sample has all of the references set to SpecificVersion = true and it includes a reference to every Infragistics control and even some of the design assemblies. Visual Studio has some serious performance issues when you try to select this many reference, so basically, it just locks up on me.
If you can set SpecificVersion to False and get rid of the unneccessary assemblies, you can Submit an incident to Infragistics Developer Support and they can check it out and tell you why it's not working.
