You have to set AllowDrop to true
I have attached a zip file to this post (zipped using WinZip 12.0)
I don't have a .RAR extractor, please zip the sample if possible.
OK, I've attached a sample project - it is in VS2008 format, let me know if you have a problem with this.
The attached project is the infragisitcs sample called "UltraTree Drag and Drop VB", *but* it has been modified such that the UltraTree is created at runtime rather than at design time.
You should note that the dragdrop feature does not work.
Thankyou for your assistance.
