860
Accessing settings files after installing a hotfix set of DLLs
After replacing the original V8.3 DLLs with the latest hotfix, my application dies attempting to access various settings files as they have embedded references to the previous assemblies. Is there a way to update the references.
  • 860
    Having deleted the settings files, the application is failing because
    Could not load file or assembly 'Infragistics2.Win.UltraWinDock.v8.3, Version=8.3.20083.1009, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
    Stack dump for exception
    Message ---Could not load file or assembly 'Infragistics2.Win.UltraWinDock.v8.3, Version=8.3.20083.1009, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
    This is happening in the InitializeComponent method of a form as it calls GetObject and passes in a string.
