Simple question (I hope). I'm using your ultraNumericEditor to let the user spin between 0 and 300 by increments of 1. The standard Windows control (System.Windows.Forms.NumericUpDown) starts to accelerate if the user holds the button downs and spins through about 10 numbers. There must be a way to get the ultraNumbericEditor to do the same. I'm guessing it's a property or something, but I'm not seeing it.
Andrew
Hi Andrew,
I don't beleive there is any way to do this currently. You should Submit a feature request to Infragistics
