I have groups and within group I have column in the grid. I am making my first group as fixed.
group1.Header.Fixed = true;
I am facing problem in displaying fixed line in group by rows. In the normal rows fixed header thick line is coming but in the groupby rows it is not coming. Can you please provide the solution. As it is causing inconsistency in my screen.
However, when I scroll columns fixed columns line appears automatically.
Click below link to see the screen the screen for showing freezed column row after scrolling.
Thanks and Regards, Rosy Malhotra
Hi Rosy,
If the line is showing up sometimes and not others, then it looks like a bug to me. You should Submit an incident to Infragistics Developer Support. If possible, include a small sampleproject demonstrating the behavior you are getting.
Pls reply on this as i am still wating for a soluition
Thanks and Regards,
Rosy Malhotra
Hi Mike,
Please try now, as suggested I have uploaded the images.
Thanks and Regards,Rosy Malhotra
The links you posted here are not working for me. You can attach image files to your posts directly and the image will show up in the post.
