Using the UltraWinScrollbar, is there a way to turn on scroll tips like you can on the scrollbar in the UltraWinGrid? I would like a tip that shows the value of the scrollbar.
I don't believe that there is any functionality built into the scrollbar to handle this, but you could certainly show your own ToolTip:
private Infragistics.Win.ToolTip tt;private void ultraScrollBar1_MouseHover(object sender, EventArgs e){ if (this.tt != null && this.tt.IsVisible) this.tt.Hide(); this.tt = new Infragistics.Win.ToolTip(this.ultraScrollBar1); this.tt.ToolTipText = this.ultraScrollBar1.Value.ToString(); tt.Show(Cursor.Position);}
You could do a similar thing in the MouseDown or ValueChanged event, changing the location of the ToolTip accordingly.
-Matt
