Im using the wingrid, and have a dynamic datasource attached to it. An ordinary datagridview you just press the downarrow to get a new row to fill. That doesnt seem to be the case with my ultragrid. Am i just missing a property to set ? Im not interested in the addrowbutton unless im absolutely forced to use it
You might want to try setting AllowAddNew to TemplateOnBottom.
I'm not aware of any property that will enable this behavior. You could probably do this by handling the KeyDown event yourself, i.e.:
private void ultraGrid1_KeyDown(object sender, KeyEventArgs e){ if (e.KeyCode == Keys.Down && this.ultraGrid1.ActiveRow != null && this.ultraGrid1.ActiveRow.Index == this.ultraGrid1.Rows.Count - 1) { e.Handled = true; UltraGridRow newRow = this.ultraGrid1.ActiveRow.Band.AddNew(); newRow.Activate(); }}
You might want to account for exiting edit mode on certain cells, or not doing this if you're in edit mode.
-Matt
