Before installing the infragistics controls, i have closed all the development envirnoment and i installed successfully. After installation, i have click the "Create NetAdvantage Visual studio tool box" which is in start -> Programs -> infragistics Netadvantage 2006 Volume 2 CLR 2.0.
But it is showing the error as
Install path and assembly path does not match
A dialog box appeared with message below.
A reg file called RegFix.reg will be created in the toolbox utility folder for your convenience
If you give ok to the above message then it is installing some of the windows components and showing the error message as
Command " Tools.InstallCommunityControls" is not valid
Kindly help to resolve this issue.
Thanks and Regards,
Ram
