435
Disable row selection
I have created ultra gird as base grid in my project and using in different forms. In one the Form i don't want to select a row when i bound data source to this base grid.  Even i'm also setting up App Style at run time. In this style i have one Tag "GridRow_Selected"<resource name="GridRow_Selected" foreColor="0, 69, 209" imageBackgroundStyle="Stretched"><imageBackground>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</imageBackground></resource>Is
this possible for this particular grid case, i can disable the row selection?
Thanks Amit
  • 37774
    I'm not quite sure what you're trying to accomplish, but it sounds like you might be mistaking a selected row for the active row.  Could you be a little more specific on what you're trying to do and how the seleted style applies to your problem?  I might be able to point you in the right direction with more information.
    -Matt
