Hi all ,
I added a code which colors cell of the column on its value basis.
it works fine while loading the control, but when value of the cell cahnges at runtime I want to capture the event and again call my method for coloring the cell on value basis so that it will work fine even a value changes at run time not only at loading time.
to satisfy above need I called the applyColor method in the event "CellChange", but this looses the color in between and again applies it. Not getting this unlikely behavior of the grid. Am I calling method in correct event? or it should be called in some other event?
Thanks in advance,
Yogesh
I think that the best event for doing this is the InitializeRow event, since this should fire again when the cell values change.
-Matt
