I am using a TreeMapChart and i want a custom tooltip. I have columns like Category,Name,Price and Sales. The treemap chart has generated according to the category. I tried to set the custom tooltip as explained in this article
http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=2807
I see the tooltip created but the values get misplaced. The highest category displays the 2 category values and so on respectively. The least category does not have any of the tooltip instead throws a error message
No Row at position .
I really dont understand what is this problem. Could anyone help to solve this issue?
Thanks in advance
Ferdin
okay, so the relationship between the row in the datatable and the context["DATA_ROW"] isn't direct, like it is for charts which are based on tabular data structures.
i think the best way to get your real row index back is by setting a primary key on your source DataTable and then using its Rows.Find method to get the row back.
here's some sample code:
private void Form1_Load(object sender, EventArgs e) { this.ultraChart1.ChartType = ChartType.TreeMapChart; DataTable table = new DataTable(); table.Columns.Add("Category", typeof(string)); table.Columns.Add("Name", typeof(string)); table.Columns.Add("UnitPrice", typeof(double)); table.Columns.Add("YearlySales", typeof(double)); table.Rows.Add(new object[ { "Fruit", "Apples", 3, 200 }); table.Rows.Add(new object[ { "Fruit", "Bananas", 2, 100 }); table.Rows.Add(new object[ { "Fruit", "Oranges", 1, 50 }); table.Rows.Add(new object[ { "Dairy", "Milk", 4, 20 }); table.Rows.Add(new object[ { "Dairy", "Cheese", 5, 10 }); table.Rows.Add(new object[ { "Meat", "Steak", 10, 150 }); table.Rows.Add(new object[ { "Meat", "Chicken", 8, 35 }); table.PrimaryKey = new DataColumn[ { table.Columns["Name"] }; this.ultraChart1.Data.DataSource = table; this.ultraChart1.Data.DataBind(); Hashtable labelRenderers = new Hashtable(); labelRenderers.Add("MY_TREE_LABEL", new TreeMapTooltipRenderer(table)); this.ultraChart1.LabelHash = labelRenderers; this.ultraChart1.Tooltips.FormatString = "<MY_TREE_LABEL>"; } internal class TreeMapTooltipRenderer : IRenderLabel { internal TreeMapTooltipRenderer(DataTable table) { this.Table = table; } private DataTable Table { get; set; } string IRenderLabel.ToString(Hashtable context) { if (context.ContainsKey("ShapeLabel")) { int realRowIndex = this.Table.Rows.IndexOf(this.Table.Rows.Find(context["ShapeLabel"])); return "Row Number " + realRowIndex; } return ""; } }
David
Thanks for your reply. Yes i am using context["DATA_ROW"]. I am attaching the code of IRenderClass which i used here.
using System;
using System.Collections.Generic;
using System.Text;
using System.Collections;
using Infragistics.UltraChart.Resources;
using System.Data;
public class RenderLabel:IRenderLabel
System.Text.StringBuilder ReturnValue;
localDT = myData;
ReturnValue.Length = 0;
DR = localDT.Rows[RowIndex];
ReturnValue.Append("Department:");
ReturnValue.Append("\n");
ReturnValue.Append(DR["ItemNumber"]);
ReturnValue.Append("Stock:");
ReturnValue.Append(DR["Description"]);
Hope this helps you to figure out my problem.
it's hard to tell what's going on because i don't know how IRenderLabel is being implemented. what does your IRenderLabel.ToString(Hashtable context) method look like? are you using context["DATA_ROW"] to get the row index like in that KB article?
