60
SpellCheck performance issue
 I'm currently using Infragistics 8.1 and I'm having performance issue with the SpellChecker
When I put the SpellChecker to AsYouType mode
--> this.spellChecker.Mode = SpellCheckingMode.AsYouType;
And then activate the SpellChecker on a RichTextbox
--> this.spellChecker.GetSpellCheckerSettings(this.richTextBox1).Enabled = true;
 All error modes are underlined in red (as expected).
 Now when the text content gets longer (~ 100 lines of text), there is an increase delay between every key stroke and the time it gets displayed on the textbox.  So if I type a sentense, there would be a noticable delay time untill the sentense gets displayed.  And the performance issue gets worse as the richTextbox content gets larger.  Deactivating the SpellCheck would end the problem but then I don't have the mis-spelled words underline anymore.
Is there a solution you can suggest for my problem?  Thanks.
My system info:
Windows Vista SP1, 3gb RAM, Windows Form dot Net Framework 3.5,
Parents
No Data
Reply
  • 44743
    There will always be a growing performance problem as more underlines are visible on screen at once. However, it's possible there are unnecessary bottlenecks which can be removed. I would recommend submitting the issue to the support group so it can be investigated: http://es.infragistics.com/gethelp.
Children
No Data
