179
UltraNumericEditor gives FormatException when SpinIncrement set
I'm having a problem with the ultraNumeric Editor with the following settings:
this.ultraNumericEditor1.AlwaysInEditMode = true;
this.ultraNumericEditor1.FormatProvider = new System.Globalization.CultureInfo("en-US");
this.ultraNumericEditor1.FormatString = "###.# MHz";
this.ultraNumericEditor1.Location = new System.Drawing.Point(124, 73);
this.ultraNumericEditor1.MaskClipMode = Infragistics.Win.UltraWinMaskedEdit.MaskMode.Raw;
this.ultraNumericEditor1.MaskInput = "nnn.n MHz";
this.ultraNumericEditor1.MaxValue = 600;
this.ultraNumericEditor1.MinValue = 0;
this.ultraNumericEditor1.Name = "ultraNumericEditor1";
this.ultraNumericEditor1.NumericType = Infragistics.Win.UltraWinEditors.NumericType.Double;
this.ultraNumericEditor1.PromptChar = ' ';
this.ultraNumericEditor1.Size = new System.Drawing.Size(100, 21);
this.ultraNumericEditor1.SpinButtonDisplayStyle = Infragistics.Win.ButtonDisplayStyle.Always;
this.ultraNumericEditor1.SpinIncrement = 1;
this.ultraNumericEditor1.TabIndex = 0;
 This will throw a System.FormatException before the form displays complaining that the input string was not in a correct format.  If I remove the SpinIncrement settting then everything is fine.  What I would like to do is use the SpinIncrement to increment the number by some fractional amount, like 1.5.  Am I mis-interpreting the SpinIncrement here?  This only seems to appear when using the literals? in the MaskInput and FormatString.  The following code works fine:
this.ultraNumericEditor1.FormatString = "###.#";
this.ultraNumericEditor1.MaskInput = "nnn.n";
this.ultraNumericEditor1.SpinIncrement = 1.5;
Is there a way to get this to work the way I want?
